Parameterising a dimension
lucad.aVM3TV
Observer Observer
lucad.aVM3TV
Observer
Observer
How do I parameterise a dimension, a length, setting a minimum and a maximum? I have pipe sections that must be between 100 and 3000 millimetres.
I am creating an adaptive family but I don know how create this parameter. thanks
rxi.gg
Two parameters.
x
x1: if(x<100,100,if(x>3000,3000,x))
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
rxi.gg
You must to link x1 to the geometry and use the X parameter to write your distances manually
