Dimension window tag on prject
Hello, tried to insert a self made window tag but don't understand why dimension are so big.
Control unit parameter and length is in mm.
So if my line has lenght 0.3 m why when import this in the project are huge?
Thank's
Please if you can make some screenshots besides using phrases.
Thank's
Sahay_R
deleted
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Sorry is 0.030 m. It should be even more smaller than 10 times I descriube before, so more littler than what appeair in prject.
Dimension similar to windows.
If click on tag in project can't scale of modified family.
The dimension of the tag is what you see when you print the drawing sheets on a piece if paper at full size. So a polygon with 3cm edges is huge on paper, of course.
Sahay_R
Try changing the highlighted dimension to 8.5mm, which is the size of the wall tag.
A word of caution - you are using similar shapes for wall and window tags. That may cause confusion.
Rina Sahay
