I am looking for a solution to be able to dimension my project to the stud of the wall (not to the finish face). As I can see in Revit, there is only an option to dimension to center or face of wall.
Is it possible to dimension to stud, ignoring the finish?
Solved by Karol_Piroska. Go to Solution.
sure it's possible, you need to hit the TAB key few times to select desired wall face or centre (as with any other elements - "tabbing" to reference lines/planes)
Please see the attached screenshot -
