Unfortunately, Revit does not currently support placing the dimension text inline or centered on the dimension line itself, like in AutoCAD.
By default, the text appears above or with a leader (if there's not enough space). There is no built-in setting that allows the text to sit exactly in the center of the line.
You can try adjusting the text position manually by:
If this feature is important to you, I recommend submitting it as a feature request on the Revit Ideas forum.
✅ Here’s why Revit does not support "inline" dimension text:
Model-Based Clarity Over Visual Styling
Revit prioritizes clear and legible information across all views. Placing dimension text on the line itself could reduce readability — especially in busy plans or sections.
Avoiding Visual Clutter & Line Overlap
Centered text might overlap with other geometry or lines, which can confuse contractors reading printed drawings or digital PDFs.
No Risk of Misinterpretation
By keeping the dimension text above or offset from the line, Revit ensures that measurements are easily visible and never mistaken for part of the model.
Supports Automation and Consistency
Revit automatically adjusts text placement, adds leaders when space is tight, and maintains consistency across views.
Centered inline text would break this automated behavior.
💡 Summary:
This is not a missing feature, but rather a deliberate design choice for professional clarity in BIM workflows. While AutoCAD gives more graphic control, Revit emphasizes data integrity and drawing reliability.
If inline text is essential for your standards, I’d recommend submitting a feature request — but also consider the readability and BIM-related impact before doing so.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
