Dimension text in line with dimension
LisaDrago
Advisor Advisor
Message 1 of 35
LisaDrago
So - is it possible to have a dimension style setup that shows the dimension text inline with the dimension - without having to move it?
I have been looking but cannot seem to do it - is it possible and I am just missing it?
Thanks!
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
Replies (34)
Message 21 of 35
Corsten.Au
Revit file is attached if someone wants to explore Inline Annotation Family to use like Dimension..
Inline Dimension using Line based Family.Inline Dimension using Line based Family.
Corsten
Building Designer
Message 22 of 35
Anders_HMservice
Hi  j0hnp,
Sorry to wake up an old topic, i know th center text node is in the rhythm package, but have you tried making one that works with metric systems?
Kind regards
Anders
Message 23 of 35
j0hnp
I have not had a chance. Unfortunately, I am using the Dynamo translation
methods for geometry and that means that while Revit (under the hood) still
thinks in imperial, the Dynamo translation methods will use metric. The
node would probably need to be refactored to only use the Revit API methods
available to us.
john.pierson
expert elite / design technologist / dynamo package creator
designtechunraveled.com
Message 24 of 35
Anders_HMservice
Ok – Thanks anyways, you have done a great job with Rhythm in general 😊
Message 25 of 35
j0hnp
Thanks so much! Let me see if I can take a look at that node. I have a few
minor updates to be made and can add that to the list.
john.pierson
Message 26 of 35
Anders_HMservice
That's awesome j0hnp, if you need help testing, let me know.
(Notice, that im a Dynamo newbie)
Message 27 of 35
j0hnp
@Anders_HMservice Would you mind testing the latest version for me on a metric file?
john.pierson
Message 28 of 35
Anders_HMservice
j0hnp - Sure, what version is it, and where can I get it?
Message 29 of 35
Anders_HMservice
Nevermind, i got it 🙂
It works fine on single dimensions, but not if there are more dimensions in one string.
Attached screenshots.
Message 30 of 35
j0hnp
Okay, cool. It has never worked for multi segment dimensions. But, with it
working on imperial + metric now, I can try to implement that too.
john.pierson
Message 31 of 35
Anders_HMservice
Thank you @j0hnp you are awesome!
This is going to be a timesaver for me.
-Anders
Message 32 of 35
i.casalin
this doesn't seem to work for me. It goes above the line but not in the center.
Any tips?
Message 33 of 35
Anders_HMservice
Hi @j0hnp,
Again, thanks for your great work, hope all i well.
Just fyi. theres a problem when using the dimension center on dimensions in sections/elevations, its doesnt center the text. On plans it still works like a charm.
If this is only on metric, i do not know.
Kind Regards
Anders
Message 34 of 35
bone14701
@Anders_HMservice  @j0hnp  Where do I get this Dynamo code at for the Imperial version?
Jim
Message 35 of 35
RogK
so silly (being polite) that Revit, which cost a fortune, cant do straight up and easily what we have done forever and with almost every package available in preparing drawings
