dimension solid vs dashed
While creating a dimesion for two walls when I use the centerline the dimension is displaying as dashed and when using faces it shows solid. But I want to display dashed in both the scenarios.
Kindly help me out with this
dzanta
can you provide a snapshot of what you are talking about so I can better understand the issue?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Sahay_R
Tried to duplicate what you have described, @Anonymous. In both cases dimensions display in solid lines.
@dzanta - correct me if I am wrong, but Revit does not allow the creation of dimension styles with dashed lines......
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
dzanta
that is correct.  I ran into this issue a while back.  I ended up posting a Revit idea to allow for full manipulation of the display of every element within the definition of a dimension style...including linework.
Sahay_R
@dzanta - can you share the location of the idea so that I can vote for it?
Rina Sahay
dzanta
https://forums.autodesk.com/t5/revit-ideas/dimension-ticks-various-types-and-control/idi-p/6511159
You can set witness lines to center references a different pattern and a symbol.
Still, it does not answer OP's question.  He would need to place a line based family on the edges of the wall and use them to dimension.  Then the dimension lines can be centerline because they witness the center reference plane of the family.
