Dimension rounding error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have some elevations that are being submitted to the city where we have to show variations in our facade at a proscribed distance. To show compliance, I created a dimension type with 1" tolerance (exact measurements aren't critical, and I don't want fractional dimensions cluttering up the views). I have several equally spaced bays, and the exact measurement is 37'-9 1/2". On my elevation with the 1" tolerance dimensions, only one of them shows up as 37'-10". The rest show up as 37'-9". This prompts two questions--first, why is Revit ever rounding down with a 1/2" dimension at a 1" tolerance? And secondly, why is is there a different result for the same measurement depending on its location?
I've double and triple checked the exact dimensions, using the measure tool, a 1/256" tolerance dimension, and verifying the actual value in the dimension itself as well as in the properties tab. They are each exactly 37'-9 1/2". So it's not an issue of the model being incorrect or imprecise. See the attached image; the dimension string on top is the 1" tolerance dimension, while the individual dimensions below are 1/256" tolerance.
