Weekly New Knowledge Articles by Support team | Mar 2nd - 8th, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
117 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
03-Mar-22
Is it possible to show more than one Design Option for a Linked Revit model?
How to show more than one Design Option for a Linked model in Revit
No
05-Mar-22
After installing a new Revit Server Accelerator, the model data is not being cached.
Revit Server Accelerator not caching model data after initial setup
No
08-Mar-22
The message "Can't keep wall and roof joined error in Revit" appears in Revit when creating dormers for the existing Roof.
"Can't keep wall and roof joined" when creating dormers in Revit
No
03-Mar-22
Users reported that while rendering the view in Revit, some elements appear, that are not visible in the model before rendering.
Unexpected shadows while rendering the view with specific glass material applied in Revit
Yes
07-Mar-22
User reported that importing or linking IFC file created in AVEVA E3D takes long time or crashes in Revit.
Importing IFC created in AVEVA E3D takes long time or it is not finished in Revit
Yes
08-Mar-22
User reported that spot elevation shows additional digits with not rounded value for meters and centimeters unit type in Revit.
Spot elevation shows additional digits with no value for meters and centimeters unit type in Revit
Yes
08-Mar-22
User reported that stair landing and floor base quantities are incorrectly exported to IFC from Revit
Stair landing and floor base quantities incorrectly exported to IFC from Revit
Yes
04-Mar-22
How to set up Shared Coordinates in a Site or Base Revit model and how to move or relocate the model as needed.
How to set up Shared Coordinates using one Revit model as the Site or Base file
No
03-Mar-22
How to place Fabrication fittings on a side of a straight channel in Revit
How to place Fabrication fittings on a side of a Straight channel in Revit
No
07-Mar-22
Users reported that the filter rule is not displaying the associated parameter value in Revit User Interface.
Filter rule is not displaying the associated parameter value in Revit User Interface
Yes
07-Mar-22
Users reported that grids cannot be exported to IFC from some Revit projects.
Grids not exported to IFC from Revit project
Yes
04-Mar-22
Cannot access BIM 360 models through Revit on two computers at the same time.
Cannot work on Revit BIM360 projects between multiple devices
No
06-Mar-22
Where to find mechanical, electrical, or plumbing (MEP) training for beginners in Revit?
Available mechanical, electrical and plumbing (MEP) training for beginners in Revit
No
08-Mar-22
Users reported that material names are duplicated for the same materials in IFC4 export from Revit
Duplication of material name for the same materials in IFC4 export from Revit
Yes
03-Mar-22
How to create a consolidation layer based on Toposurface in Revit?
No
03-Mar-22
How to save part of the Revit model to a separate Revit file?
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
