DIMENSION CENTER EQUAL
Message 1 of 8
Hi.
i'm trying to center 2 lines with a desired dimension between walls and accidentally i achieved through dimension parameters. I put a desired dimension between equals (see attached image). But i can´t do it again.
I find this really helpfull to center objects, families, lines between objects without modifiying the objects lenght.
Thanks for your help and sorry for my english.
Replies (7)
Message 2 of 8
arunag
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Message 3 of 8
THanks for your answer but what i want is center the objects at equal distance but the center dimension remains with the value that i put in it. for example y have 2 walls but between them i need to put two lines separated 2" from each other. what i do is draw lines and use the align command but it takes a long time and effort and sometimes i forget to delete the lines.
Message 4 of 8
arunag
Just select the continuous dimension , you will see a not EQ sign, click on it , it will equalize . EQ00.jpgEQ1.jpg
Aruna
Bangalore
Message 5 of 8
constantin.stroescu
If I understand you well , you want to have a midle fix dimension placed at equal distance from both sides..
In this case I sugest:
  • draw a dimension chane of 3
  • then select  the midlle dimension and lock it
  • select the one of the mid element border ( Reference Plane) and then change the side dimension using a formula :  = (D (overall distance) - M (mid segment))/2
Better , have a look at my screencast:
https://screencast.autodesk.com/main/details/4b1cbda8-4679-4e5b-a703-bed7b566157a
Constantin Stroescu
Message 6 of 8
Thanks a lot. That was exactly what i meant.
Greetings.
Message 7 of 8
Hello
How can i center a decal on a wall?
thanks
Message 8 of 8
Same way you center a painting on a wall in reality. Create a reference center to the wall and move the decal so that its center point snap to that reference.
