Dimension Arc Centerpoint
PhilvK
Advisor Advisor
PhilvK
How do you dimension the centerpoint of an arc or circle? When I try, nothing is recognized to snap to at the center's crosshairs.
Alfredo_Medina
Select the arc wall. In its properties, activate "Center Mark Visible". Then dimension the distance between the center and the grids.
chrisplyler
Oh nevermind.
What if it's not a wall, you're measuring, but rather a structural slab that you need to identify a radius for?
