Dimension a point cloud
dtiemeyer
Advisor Advisor
dtiemeyer
I have a point cloud linked into Revit, and it seems none of the dimension tools work with it. While the Measure tool can snap to a point in the cloud, none of the dimension commands will, not Aligned, Linear, nor Spot Elevation nor Spot Coordinate.
Even typing in 'PC' for the Point Cloud snap (as mentioned in the Snaps dialog) does not work.
Can anybody else confirm this? Suggestions?
My other CAD is a Cadillac and I like to Revit to the Max!
RDAOU
Hello @dtiemeyer
Measurement tool and dimensioning tool function differently...Normally you cannot place dimensions directly on to a Point Cloud because dimensions require elements/references which can be constrained ... measurement tool ont he otherhand can snap to any planner surface
Edit:
If you are not adding any objects/elements to it and just want to dimension it as is; you can add tiny ref planes to measure to and from
What does ref planes mean?
dtiemeyer
it is a Reference Plane, in Revit.
