- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there anywhere i can download a schedule and diffuser families someone has got set up??
And diffuser tags actually....
Thanks for the tip but thats not exactly what i was looking for.
I know someone out there has a Schedule for Diffusers and Families that they have customized, say to TITUS or PRICE products. That simply populates to a schedule when dragged and dropped into the model. I dont need it to list by instance, just type.
Why don;t you download the families directly from the manufacturers, load them in your project, and create a schedule pulling field from the category? It maybe quicker than waiting for someone may or may not be visiting this forum giving it to you.
https://www.titus-hvac.com/public/software/revit/terminal%20units
Sorry, I cannot give you my content. But it's not hard to set up. Honestly, even if I could give you my schedule, you would end up reformatting it, renaming it, changing the fields used, changing their order, changing the sort-by and filter and itemization settings, etc. You can make your own just as fast, really. It will just take you thirty minutes the first time if you're learning as you work, that's all. Same with the tags. And same with modifying an out-of-the-box family and creating multiple types of it to represent the actual products.
Thanks for the reply, I'll get to work
We'd be glad to help with any specific questions/difficulties you encounter along the way.
