Embedded detail component in profile flipped in detail
1 ANTWORT 1
Nachricht 1 von 2
dtpeter2901
647 Aufrufe, 1 Antwort
We started embedding detail components in our Curtain Wall mullions and Parapet caps.  This has been working good for the most part.
We started making detail plan views that were rotated to matched the elevations they were cut from.  You know so they'd look like the old school line projection method used to create plan, section and elevations all done on one sheet.
When we did this we noticed that the detail component would get flipped inside the profile and would appear backwards.
I'm guessing this is a known issue, but I couldn't find anything about it.
I'm wondering why it behave this way and if there's a better way to nest things.
Thanks in advance.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: dtpeter2901
This is a known issue , and as a  work-a-round you can create a detail component for each rotation needed and not one for all.
There is another thing , If you have a plan region in this area, turn it off or shift it away from mullions,,, This cause the detail portion of the mullion to flip 180 and offset but I can not know why this weird action.
Hope these ideas can help.
