Difficulty in adding angular dimensions to the same family object.
promosengenharia
Message 1 of 15
promosengenharia
Boa tarde a todos, como estão?
Estou usando o google tradutor, então peço desculpas pelos erros.
Preciso fazer uma família de tirantes para um muro de contenção, e vou precisar inserir o valor de dois ângulos diferentes,
um em relação ao eixo Y e outro em relação ao Z, mas não estou conseguindo.
Alguém pode me ajudar por favor?
Abaixo está o arquivo em questão. Muito obrigado.
Accepted solutions (3)
Replies (14)
Message 2 of 15
promosengenharia
Good afternoon everyone, how are you?
I'm using google translate, so I apologize for the mistakes.
I need to make a family of ties for a retaining wall, and I'll need to enter the value of two different angles, one in relation to the Y axis and the other in relation to Z, but I'm not succeeding. Can anyone help me please?
Below is the file in question.
Thank you very much.
Message 3 of 15
Try this one.
Message 4 of 15
I created another Ref. Line in Plan View, hosted the existing Ref. Line to this new Ref. Line (via Edit Work Plane=>Pick Plane), pulled the "Angulo" Dimension between the 2 Ref. Lines in 3D View and pulled the "Rotate" Dimension between the Ref. Line and Ref. Plane in Plan View.
Message 5 of 15
Why can't you rotate the family directly in the project?
Message 6 of 15
Funny, that's the first thing I thought of and tried. I couldn't readily figure out how to rotate about the x,y origin point. Even tried making the RLs "Not a Reference", but to no avail.  What do you think? What am I missing, besides more coffee?  😉
Message 7 of 15
...that and it's also a square base.
Message 8 of 15
Oh I didn't notice there was a base.   Nevermind then.
Message 9 of 15
promosengenharia
Thank you so much BARTH BRADLEY, I don't know how to thank you,
this is exactly what I need.
God bless you.
Message 10 of 15
You're welcome.
Mark my post as the Accepted Solution.
Message 11 of 15
FWIW.  Just killing time until the sandwiches arrive.  😉
Message 12 of 15
promosengenharia
@barthbradley.
Good morning, how are you? Could you point me to a video or course that teaches methods of creating families,
including the one you used to solve my problem, please? Thanks.
Message 13 of 15
@promosengenharia wrote:
@barthbradley.
It's all about Work Planes.  I would suggest using Google to search for tutorials, articles and videos about Work Planes in general.
Here's a kick-start:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
Message 14 of 15
clacampos
Olá @promosengenharia
Bem vindo a Autodesk Community!
Nós temos foruns em portugues o forum de Revit fica neste link então fique a vontade para postar em português lá, onde temos vários especialistas em REvit.
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
Message 15 of 15
promosengenharia
Obrigado.
