I have a small office renovation project. There are a couple rooms that have a certain use in the existing plan but a different use in the renovation, i.e. a Conference Room becomes part of the Lobby. I want the room tag to say "Conference Room" on the Demolition Plan but "Receptionist" on the Construction Plan. If I try to tag both plans I get error message. I even created a duplicate Room Tag but it won't let me put it in the same space as another room tag. The phase is not changeable for the Room Tags
How can I show different room names for the same space on different sheets?
There are two approaches to show demolition rooms:
1. Use phase filter:
- Main demolition view: Set the phase to New, phase filter to Show previous + Demo, turn off rooms.
- Existing room view: Create another plan view, set the phase to show Existing, phase filter to show All. Turn off everything except to Rooms and room tags.
- Place both views on sheet.
2. Use view filter:
- Demolition view: set the phase to Existing, phase filter to Show All.
- Create a view filter using Demolished Under Phase criteria to override all demolished item to match your demand graphics. You can tag existing rooms in this view directly.
Hi @twallVCXPH
Thanks a lot for posting your question to the forums! Have the solutions suggested by @ToanDN @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
