Difference between Create New Project and Create New Project template?
epolydorou01
epolydorou01
What is the difference between Create New Project and Create New Project template?
HVAC-Novice
Check out what templates do... and create one that works for YOUR needs.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-C...
The one creates a project, the other a template (you probably could see that :-). You can create a project from the template, or a project can be saved as a template.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
One creates a new RVT file format and the other creates a new RTE file format.
