dialogue window missing
ADT267
Message 1 of 8
ADT267
WANTED: list of ideas as to restoring a dialogue box (in this case Warning), so far I've tried:
Restarting programme
Opening another project
Alt-spacebar arrow trick
changing screen resolution
Is reinstalling the software my only hope... 😞
Replies (7)
Message 2 of 8
indiana_j0nes
Try and locate the Revit.ini file.
Before you follow any further instructions, just make a backup of this file and also note its path.
Now in the ini file look for the following lines:
SuppressShowButtonMessage=0
SuppressShowMassWarning=0
If they are set to =1 change them to =0
That should ideally do the trick.
Let us know.
Cheers, K
Kunal Tuljaram Gaidhankar
Message 3 of 8
ADT267
Thanks, but still no luck...
Showing: SuppressShowButtonMessage=0
Missing line: SuppressShowMassWarning=0
Message 4 of 8
bin
Not sure what you are looking for, the warning like mass visibility, Raster printing, or the warning of model that you can access from Tab?
Message 5 of 8
ADT267
Warning of model accessed from the tab or typed command "WR".
Message 6 of 8
indiana_j0nes
Is this a recent issue?
From an another thread it appeared to be a bug form a Infraworks Updater.
Maybe check that?
Message 7 of 8
indiana_j0nes
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2020-can-t-see-alert-windows/m-p/90779...
Something Similar but with Revit 2020 discussed here..
Message 8 of 8
ADT267
YES!!! uninstalled Infraworks Updater and seems to be working fine now.
Just as a matter of interest, I'm running Revit on a double screen.
Thank you
