Please check the attached pdf file. It is an hand rail project for stadium.
1. Double glazing prepared by rail with rectangular profile.
2. Aluminum profiles are prepared by generic model.
3. Circular hand rail prepared by rail with circular profile.
4. Support for the circular rail prepared by the generic model.
Here my question is can i choose any method to prepare any items? Especially this is an standard project for FIFA2020, But i am in beginner in revit. Also there is LOD and MASTER FORMAT from the consultant.
Thajuddeen.
Yes, you are on the right track
Use a rail for the glass. It's probably better to use a handrail for the handrail, which is a separate feature within the railing. You can adjust the returns of the rails as shown in your image if you use this. You can use custom balusters for the aluminium profiles and handrail supports for the circular railing.
Like @Anonymous mentioned..
I am not sure if your aware of online resources for such requirements.
Many a times the manufacturer made BIM components have appropriate LOI's
For example you can find some here: https://www.bimobject.com/en/product?freetext=railing&country=qa
Kunal Tuljaram Gaidhankar
@Anonymous be careful, sharing such documents could get you into trouble.
