Diagonal riser not counting on a U-Shaped Stair
renan.jose
Message 1 of 40
renan.jose
Hi, after drawing my u-shaped stair using model lines and draw it's boundaries i'm trying to add the risers but the risers on the diagonal are not counting up. What should i do to make it work ? Thank you.riser diagonal.png
Replies (39)
Message 21 of 40
@renan.jose
See attached file.  Every step counts and the plan looks okay.  The 3d has some defects at the pointy corners so youc an choose to live with those or add a tiny bit of dimension to the corner.
Message 22 of 40
Now isn't this a heck of a lot better looking stair! In fact, this actually looks like something that could be precast and delivered to the job site.
In-Place Modeled:
In fact, this looks so good, I'm giving myself a solution credit.
Message 23 of 40
renan.jose
Looks great, could you explain how how did you made that in a little screencast ? Thanks
Message 24 of 40
renan.jose
Perfect, could you explain how did you made that in a little screencast ? Thanks
Message 25 of 40
bin
No problems, I'll record a video shortly.
Message 26 of 40
Ever create an In-Place Component?  That's what I used.
The In-Place Component is a series of joined extrusions that were based on the ugly geometry that Revit produced when I created Monolithic Stairs from your Model Line layout.  I sketched the outlines for the extrusions on Work Planes that were found by picking a plane on the existing Monolithic Stairs (Work Plane=>Set=>Pick a Plane).  Three separate extrusions was all it took. I modified the Structural Depth  slightly from the Mono design, joined them altogether to remove the visible edge between them, and clicked "Finish".  Voila!  Just a few minutes of easy breezy work to create something that actually looks like it could be precast and delivered to the job site.
p.s.  you could do it as a Family too. Also, you can add parameters to make it flex.  Ain't Revit grand! Smiley Wink
Message 27 of 40
Here is the actual component stair with diagonal risers meeting at a point.   No defects.
Message 28 of 40
bin
Hi Renan,
This is a short video showing you my approach, and a possible workaround of it. (Turn on the Subtitles)
ToanDN has modelled a quite perfect one, I am also interested to know how it was done.
Thanks very much.
Message 29 of 40
renan.jose
Ì couldn't do it using the original model lines (without move them a little bit) like you said you did.
https://autode.sk/2U36SgI
Message 30 of 40
renan.jose
Do you have any idea what i did wrong following your video instructions ?
It didn't generate the stair even after changing from smooth to stepped.
https://autode.sk/2BFH8QE
Message 31 of 40
Corsten.Au
Test this.. There are various components which needs modification to achieve the results...Test this.. There are various components which needs modification to achieve the results...
Corsten
Building Designer
Message 32 of 40
renan.jose
The problem is that i really cant change the architect original design, i'm just converting from autocad to revit. It must follow those green lines like this:18022019 02.PNG
Message 33 of 40
Corsten.Au
You can follow those green lines..
but differentiate between
1. Boundray ( green lines )
2. riser ( black lines )
3. path ( blue )
heres the screencast for you..
Corsten
Building Designer
Message 34 of 40
bin
I'm not too sure, I was using your file, so it should have worked.
If you must model the stairs exactly the same as the CAD lines, I recommend that instead of spending days try to model it as a proper stairs, just use Model in place.
What do you think?
Message 35 of 40
See file attached (2019).
Message 36 of 40
renan.jose
Sure i could do that using individual masses but i really would like to learn how to make a proper stair without jerry-rig since i will send the RVT  to other ppl so they can make the structure and the finishing. @ToanDN design looks perfect but need a few adjustments to fit in place but i really don't know how he did that (i just copy and paste his stair design into location).
Message 37 of 40
You can edit my stair, click on a run or a landing and edit sketch to see. You should rebuild it to match your design.
Message 38 of 40
renan.jose
I did it @ToanDN but how can i change the actual riser height ? i need to change it from 0.1667 to 0.175 in order to make it work as you can see on 3D but the values are locked (grey). Thanks
Message 39 of 40
See attached:
- Select the stair and change the Desired stair height and Desired number of risers from properties
- Edit stair and modify the sketch to match the above.
Message 40 of 40
Hover your mouse over each riser, one of the risers says boundary, not riser. Once you change that one stair the counting of risers continues.
