DFX/DGN import not working when file was exported from 3ds MAX 2019
I can get it to load into revit but it gets stuck at 3% then it just goes into what seems like error, i have let this run for 24 hours and it still is not finished.  Anyone able to take a look at a file.
martinTstewart_Adsk
Autodesk Support
Autodesk Support
Hi bderry,
  • What Revit release are you using?
  • Do you have AutoCAD? Could you bring it into AutoCAD first and save as DWG to see if DWG works better?
  • Or have the 3DS Max source export directly to DWG instead for you?
  • Are you sure you want to "import" rather than "link" into Revit?
  • Could it just be the size of the file that is the issue? How big is this file?
  • Maybe it's bogging down due to your hardware specs(?) How much RAM are you working with?
Martin Stewart
AEC Support Specialist
-We are running the most current version of Revit 2019.
-We have done it with every file type that Revit can import.
-No I am not sure but every way that I import/link it isn't able to import. It gets to 3% and then hangs.  I have let it go for 2 days and it hasn't imported.
For context.  I can make the file into a obj and bring the file up in Microsoft paint 3d without issues.
-it is a 2 gig file.  I can import it into 3ds max without issues.  If I could output a revit file from 3ds it would be a lot easier.
-I have 12 gigs of ram on this computer but can go up to 32 gigs of ram if needed.
@martinTstewart_Adsk wrote:
Hi bderry,
  • @martinTstewart_Adsk wrote:
    Hi bderry,
A 2GB DXF file to import in Revit is huge.  12GB RAM is certainly too little for this task.  Try it on a computer with 32GB or more RAM.
Another option is to break down the file into smaller chunks and import them.
We have tried to load the files with 32GB of RAM and it is still not working. It keeps stalling at 3% continuously. We will install the program on a machine with 64GB of RAM to see if it will work.
