Detailed Staircase in Revit, mortar issue
Hello all,
I'm trying to add mortar as well as tread, riser, and structure for the staircase. What I did is I tried two staircases on top of each other, both monolithic, in which the base is just the structure, and then the staircase on top has a layer of mortar (monolithic material that is 2cm in thickness) with tread and riser.
The issue is that the first step is missing the mortar from the riser side.
I tried different ways but I've found this issue to be persistent.
Is there any other way without having to do 3 staircases at the same place?
Link copied
