Edit section head family head and lines
4 ANTWORTEN 4
Nachricht 1 von 5
elisag23
268 Aufrufe, 4 Antworten
Hi, I am trying to build my own annotation families, starting with the Section tags.
I'd like to replicate the tag you see in the first image.
When I try to edit the Section head family, I can't get the text to position itself correctly. I want it to be rotated 90 degrees in the direction of the section.
I also want the lines to be shorter and not go through all the drawing.
How can I achieve this two things?The text doesn't appear rotated as in the family editorThe text doesn't appear rotated as in the family editorTrying to edit the familyTrying to edit the familyExample of section tag I want to recreateExample of section tag I want to recreate
4 ANTWORTEN 4
Nachricht 2 von 5
ralphdenhaan
als Antwort auf: elisag23
Revit-How-to-create-a-section-head-with-rotated-text.html
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 5
elisag23
als Antwort auf: ralphdenhaan
Thank you.
What about the lines, is it possible to make them shorter like in the example?
Nachricht 4 von 5
ralphdenhaan
or:
Cycle Section tail to none and drag:
Nachricht 5 von 5
