- Mute
- Permalink
- Report
Hi! I'm wondering if anyone has any success stories for a workflow from Revit to 3D printing. I know there is a lot out there and I know how to export an STL file and make a print, but I mean as far as taking a very detailed model used for CDs to a clean, successful, good looking print. Machine to be used is a plastic filament extrusion printer (similar to the way a makerbot work but a different company). Typically you need a "watertight" volumes to print well and I'm wondering if there's a best practice to get there.
We're taking a detailed model through to a smaller scale solid print- meaning windows and mullions should be expressed but only in relief, not a void looking into the interior. I essentially want to shrink wrap the building and only have that form left... but how?
So I hid all the extraneous stuff - everything inside, gutters and snowguards, exterior louvers modeled as real with tiny little fins.
But.... it's revit. Sloped skylight walls don't join with the lobby roof properly. Some wall corner joins are a little funky. There are little holes at eaves if the roof conditions weren't modeled perfectly. I need to infill the openings left by the louvers.
Also - my walls have a thickness. So instead of printing a single exterior shell I imagine the 3d printer will print the interior surfaces of the wall as well which sounds like double the printing time?
So what now.... my first insinct would be to take this into another software (rhino) to manually try and close up holes, then use something with a mesh fix function (like 3d max maybe? deskartes? zbrush?) to examine and fix the mesh. If the wall thickess ends up being an issue I'd basically remodel all the exterior faces in rhino.
All those things sounds pretty tedious.... any thoughts?
