Detail within wall not showing in section view
Message 1 of 28
I'm trying to get the wall details to display in the section drawing I'm working on. For some reason it just won't work even though I'm on fine detail. It shows up when I go to a floor plan though.
Replies (27)
Message 2 of 28
kadmonkee
have you assigned a cut pattern to your wall type components?
select wall type and edit type, each component that makes up the wall may have a material assigned to it.
also when you select the material there may be a cut pattern assigned with that material
select the material and look on the graphics tab to assign the cut pattern.
other way is to use detail components to fine tune your detail
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 28
Luiscko
You need to check if in Visibility graphics is not overridden the detail it could be a reason, there are some times that you override your detail element and always have the same level of detail where ever have in your graphic interface.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Message 4 of 28
All detail levels are currently set to "By View". There are no overides currently in place.
Message 5 of 28
The insulation and gypsum wall board have wall cut patterns assigned, whereas the other do not. Either way, shouldn't at least the lines between each wall component be displayed on the wall when viewing it in section view?
Message 6 of 28
kadmonkee
yes they should
try switching from hidden to course and back sometimes views act up.
try finding a cut pattern for that wall type to see if it responds your way
also check the view scale to detail level correspondence
Manage Tab/ Additional Settings/Detail Settings
some scales will not show up in Fine , Medium or Course based on that table
thank you
Message 7 of 28
AFatRat
Check your phasing. View and wall properties.
Message 8 of 28
+1 on phasing. Is your wall existing?
Message 9 of 28
I tried adjusting the phasing on both the wall itself, and for the detail view. Still not displaying what's inside wall.
Message 10 of 28
I tried switching between coarse, medium, and fine repeatedly with no change in detail. I also added the scale I'm using to those available in fine, and still not working.
Message 11 of 28
Adjusting how?
Which phase does the wall belong to?  What are the phase status and phase filter of the view?
Message 12 of 28
I tried every option provided to me in the phase section of properties for ball the detail properties page and wall properties page. Other than that, not sure how to do anything or check anything else for phasing.
Message 13 of 28
Try Phase filter = Show Complete? Share the file if you can.
Message 14 of 28
I tried that and no success. I've attatched file.
Message 15 of 28
Dude your section didn't even cut the wall.  It basically showed the elevation of the wall.
Message 16 of 28
jdcarlingJQBC3
I tried that and it didnt work in addition to everything else.
Message 17 of 28
jdcarlingJQBC3
I tried everything here too and definitely am cutting the wall and what is weird is one section show correct and the other doesn't. with all the same settings.
Message 18 of 28
I was having a similar issue with a stacked wall.  I could see the detail in the lower wall, but all detail was missing from the upper wall.  It ended up being an issue with my sill wall sweep cutting into the wall and causing this odd error.  I simply deleted the sweep, made a new sweep, then everything showed up in the section.  The attached image shows the detail with added annotations, but you can see there are no lines for the gyp, stud, sheathing, or siding above the sill.  I'm not sure if you have any sweeps in your model (your siding maybe?), but I'd advise giving them a look if you do.
Message 19 of 28
Corsten.Au
Try Parts Visibility...
Corsten
Building Designer
Message 20 of 28
PDSF
I'm reviving this thread because I am having the same issue. It's similar to what @Anonymous  reported, but this isn't a stacked wall, although it may have started that way. Currently it's a 30" high wall with a sweep and a separate wall containing a storefront sitting above it (whose detail appears just fine). I just created the sweep, so I can't imagine that deleting and re-creating it will help, although I suppose I could try. But does anyone have any other ideas? TIA.
