Detail/Visibility Settings aren't showing for Revit Linked File
concepts.tag
Message 1 of 12
concepts.tag
Hi!
I'm currently trying to hide grid lines from a linked revit file, but after opening the Visibility/Graphic settings and clicking Revit link, the display settings aren't there. A video said it should be there so I can change the display of those lines and other items from the linked file.
Thank you in advance for your help!
Replies (11)
Message 3 of 12
concepts.tag
Thanks for replying. Unfortunately, it takes me to the same screen and I have the same problem - no display setting column.
Message 4 of 12
Annotation 2020-02-04 120036.jpgAnnotation 2020-02-04 120059.jpgAnnotation 2020-02-04 120113.jpg
Message 5 of 12
concepts.tag
It's not there...
Message 6 of 12
What is your screen resolution and windows display scaling?
Message 7 of 12
concepts.tag
1920 X 1080 and 125% - both recommended
Message 8 of 12
Try 100% and restart revit.
Message 9 of 12
concepts.tag
Okay. I'll try that now.
Message 10 of 12
concepts.tag
No, it didn't work sadly.
Message 11 of 12
Try a repair installation.
Message 12 of 12
Basam.Yousif
This is weird issue ....
What is your Revit build? Did you consider installing any updates? Make sure your Revit build is the latest - that is important. Use the Desktop App (and make sure the DA itself is up to date!) then relink the model and see.
is this issue happening with all models or just this one? what if you make fresh test models - do they get this issue too??
