Detail line dissapear
magdalina.doshevaSNP34
Hi, Everyone. My detail lines dissapear in floor when I draw it. Can you tell my what is the solution? Thanks!
hmunsell
need more information, maybe a screen capture or two.
Howard Munsell
Samantha-G
Does it give you an error in the bottom left corner to tell you that it is turned off?
Sam G, CM-BIM
Revit Certified Professional
Are you sure they are Detail Lines?  Detail Lines are drawn at the Detail Plane of the View -- the plane closest to you -- so nothing could be "blocking" them.
It goes all right, when I restart Revit. Thank`s everybody!
