Desired Upside-Down Text
konetarchitecture
Message 1 of 11
konetarchitecture
I would like to rotate my text so that it reads upside-down on my accessible parking space drawing. ("NO PARKING" in the access aisle.)
Revit will not allow me to do so.  Is there a work around or a method I am unaware of that enables one to place text upside-down in a view?
Replies (10)
Message 2 of 11
Untick this box for text notes.  However, for parking text, I would use model text instead of annotation text.
Message 3 of 11
konetarchitecture
Thanks for the quick answer!
Message 4 of 11
coyned_suir
Thanks for that solution, a simple thing like that was wrecking my head when I was in a rush to get something done
Message 5 of 11
laurence_uy_eq
Hi! Is this possible in Family Creation, for example, in creating a Template?
Message 6 of 11
AbbyCZQ26
I am having a similar issue, but regarding a label within a parking space tag instead of text note. I would like for the parking tags to read as they will be painted on (shown in red below), so some tags will need to be upside-down/inverted. I've tried the "keep readable" parameter on the tag label, as well as the "rotate with component" in the tag family, but no luck so far. Any ideas?
Message 7 of 11
laurence_uy_eq
Just edit or resave to a new file your tag family and uncheck the "keep readable". then click "Load into Project and Close" the Family Editor.
After editing, it will become like this
Message 8 of 11
AbbyCZQ26
I tried reloading the tag without "keep readable checked" and it still won't rotate the way I need it to. It doesn't allow the text to read upside-down. It appears that this is possible with room tags as you have shown, but for some reason my parking tags don't have this capability. I even copied/edited the room tag and changed the family category to be parking tags and reloaded, still no luck. Anyhow, thanks for the help.
@ToanDN any suggestions?
Message 9 of 11
If they are actual parking numbers then you could use a model text in the parking family.
Message 10 of 11
AbbyCZQ26
That's a good idea! Is there a way to get the model text within the parking family to act as a label, following the "mark" parameter? Each parking space will need to be numbered individually.
Message 11 of 11
kirkQFCXD
This solution kinda defeats the purpose of having labels as I will have to re-notate each window and door.   I have a plan that I need to display as rotated 90 degrees in one view for a an enlarged, do these other labels just not have that function? I am trying to avoid manual notation.
