I am preparing a LandUse Schedule and it has around 50 Column in it , is it possible to freeze the 1st column or row of the schedule ?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
What do you mean by "freeze"? You can hide things if that's what you want
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Are you trying to make it non-editable? That won't and can't happen, because the schedule is a live link to the model. If you want a static column, I would create it with linework,make it look right, not have the information in the schedule, and put them together on the sheet.
You cannot Freeze Rows or Columns of a schedule in Revit like you can in Excel.
You can duplicate the schedule and hide every column except for the one you want to show, open both schedule views and place them side by side. Still, it doesn't work well if your schedules are long and need vertical scrolling.
Pretty silly to not be able to do such a simple thing as keeping the headers on screen while you scroll down the schedule! But I've got a pretty silly solution to it - stick post-its on your screen to mark the columns of interest. Those will stay in place if you scroll vertically!
I believe this functionality has been recently added to Revit 2020? The silly workaround is for earlier versions (my current projects are in R2018 and R2019). Glad they finally got this taken care of!
