Design Options
Design Options
zs-17
Message 1 of 15
Design Options
zs-17
Hi
I created a design set with 2 options, my objects are already set between the 2 options. I want to transfer some objects for example from option 1 to the second. I get an error message that prevents me to do it. If I delete an option, all included objects will be also deleted.
I want to be able to control my objects between options. How to do it, please?
Many Thanks
Replies (14)
Message 2 of 15
Clipboard Cut (or Copy)/Pasted Aligned to Same Place between Option Sets.
Message 3 of 15
ennujozlagam
you can refer to this Article and see if helps. thanks
Message 4 of 15
zs-17
Works with some objects only. I can't paste to the Main Model too. Is there a way to paste it to the Main Model or delete the set and to keep my objects?
Message 5 of 15
zs-17
I didn't find all that I'm looking for in the link.
Message 6 of 15
ennujozlagam
have you check this? thanks
Message 7 of 15
zs-17
Yes, I did. What I need now is delete the option set I created without deleting the objects or removing the objects back to the Main Model.
Message 8 of 15
martijn_pater
This makes no sense whatsoever... Just copy the objects to the design sets to include them or to the main model to include it everywhere... or use cut to move it (cntr+X or shift-delete). First copy/cut, switch Active Design Option and then Paste (aligned to same place). Switch and paste to multiple Design Options if it needs to be included in multiple Design Options.
Cut to clipboardCut to clipboard
Message 9 of 15
_Vijay
Try to uncheck this box.  then copy or cut the option.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 10 of 15
Clipboard Copy/Cut and Paste will work. I think you will make life much easier on yourself if you set up and switch between DEDICATED VIEWS.  There is no Design Option Workflow without Dedicated Views.  That's my TIP of the day. You'll thank me later.   Promise.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Message 11 of 15
zs-17
I tried this option it works with a couple of objects but not with all objects to remove it to new projects. I didn't understand the error.
Message 12 of 15
zs-17
I don't have a problem with the selection, it's with pasting lots of objects.
Message 13 of 15
zs-17
I think the idea is to create a view for each design. It looks like a better idea than Design Options. Does it work after the mess I did in Design Options?
Message 14 of 15
Dedicated Views are part of the Design Option workflow, not a replacement or alternative to Design Options.  As for "the mess" you say you made, I have no idea what you did, but I am certain that creating Dedicated Views will make it easier to "fix" and manage.
Message 15 of 15
zs-17
Ok. Thanks a lot
