Design Options
Design Options
anthonywPWC
Design Options
anthonywPWC
I have a house that we will be doing a remodel and addition in.  I have the current house plan drawn, but now I need to make the changes for the addition and the renovation.  I was under the impression that the design options would help with that, but I can not delete a wall or a window, without it changing in the current house plan also.  Any way of doing this with out having a separate file?
Hello!
Create two design options. In the first you need to put all the objects intended to be deleted/modified, then create or duplicate a second design option. In this you will create what you want, without see and modify the first option.
I hope it helps!
Alfredo_Medina
@anthonywPWC
Based on what you have described, what you need is Phases, not Design Options.
