Hello All,
I have my first project with 2 design options which works fine when selecting these options.
But when want to select the specific design option on a floor plan it is greyed out in the Visibility/Graphic Overrides. So I can't select the desired option.
How can I fix this?
Hello All,
How can I fix this?
Solved by Alfredo_Medina. Go to Solution.
Most likely, that view is controlled by a view template, and Design Options is included in that view template. Open the view template, find Design Options, and turn off that setting from the Include column.
Thank you for the reply.
Your suggestion was correct!
