Solved by Darin_HDR. Go to Solution.
If you add a sill family to your window family for some reason revit will not automatically create an infill wall.
the sill is a generic model family hosted in a wall
subsequently added to whichever window or door family needing a sill
... or simply change the infill wall to a Curtain Wall with Empty System Panel.
My solution was to create a new wall type called opening comprised of only a created material called opening 1mm thick ( the minimum allowed by Revit) then replacing the infill wall with that. In plan I used the "override graphics in view" to change that wall to a hidden .125 linetype with a very near white color. It shows in a print, but you need a magnifying glass & very good eyes to see it
