Demolition not transparent with Colour scheme on
kecix3c
kecix3c
hello, i encountered problem with demolition transparency as i insert a door on the existing door, the blue line appeared as revit will make opening for that particular new door. However, when the colour scheme on, the opening didnt show the colour scheme colour. how do i get rid of this ?
Same goes the the other demolished wall,  the wall still show solid white even though i change the phase filter
*refer the cloud item*
Change the phase filter to show demo only, select all demo elements and override graphics in view, and change the transparency to 100%. When done, change the phase filter back to show new + demo.
Try creating a new material & name it, say, demolished object.
Give the object a transparency of 100%, color: white, refraction: air
In object appearance tab, tick "use render appearance"
Go to Phases: change the material setting for the demolished phase, then Use this material
In your view properties tab, make sure your phase is set to show "demolished"
