I am unable to use object styles or visibility graphics to update conceptual mass section line weight. Only override by element works....?
Here is a link to the example of what is going on:
Any help is greatly appreciated.
Marla
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Hi @htimsm
In Object Style and/or Visibility Graphics you are changing/overriding the line weight of the whole title/section Mass...That does not override the subtitles/categories/sections.
When you are doing the override using Right Click >> Override by Element; you are basically overriding the lineweight of the Form ... if you want to apply such override through Object Styles or VG; you need to expand the Mass section/title and change the Lineweight for the Form (or any other related part of the mass when/where applicable).
@ToanDN lol you deserve a big KUDO for that : o)
I've also noticed that phase filters will override any changes to object styles depending on what they are set to. Possibly best to create the mass on the New Construction phase even though intuitively you might think it should go on the Existing phase.
Michael
