Demolished shading in section
RobDBrown
Message 1 of 9
RobDBrown
Seems like a simple enough solution but I cannot get the shading for the floor and Structural framing beam to be the same weight
Any ideas would be appreciated.
Rob
Replies (8)
Message 2 of 9
Show your Phasing Graphic Overrides.
Message 3 of 9
RobDBrown
Both cut and projection lines in Demolished are set to the same weight ?
Message 4 of 9
Can you share the file here?
Message 5 of 9
RobDBrown
Here you go
Message 6 of 9
Set the Floors category's cut pattern to solid white instead of invisible.
Message 7 of 9
RobDBrown
Thank you for the solution however i don't understand why this setting shouldn't also apply to structural framing however it works with the fill hidden for that element ?
Although it seems to solve the issue it isn't ideal when using a black blackground for drafting in Revit. (see screenshot)
Do you have any other ideas on why this is happening ?
Message 8 of 9
No I don't.  If you don't want to use the solid while cut pattern for the walls then create parts from the walls and set the view to show parts.
Message 9 of 9
I understand why.  It's all about Hierarchy. Your View Template Category Overrides are "fighting" Phase Filter Graphic Overrides.  You can do away with VT Category Overrides and just use a Selection Set Filter to get to where you want to go.
Help | Element Visibility Override Hierarchy | Autodesk
