Delete the Import Categories in Revit
3 REPLIES 3
BIMAbhi
1621 Views, 3 Replies
We can't delete some Import categories (from visibility Settings > Import Categories) after deleting the link from the manage link tab in Revit interface. Is ther any process to do this, please share.
Thanks & Regards
BIMAbhi
3 REPLIES 3
GHASEM_ARIYANI
in reply to: BIMAbhi
hi
I did not understand you??
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
ennujozlagam
hi, try to double check if the import categories is link or import. check every view. hope it helps. thanks
in reply to: ennujozlagam
Thanks ennujozlagam, had the same issue today and you helped me realize my dwg was imported and not linked. Really wished I knew who did this!
I couldn't finish checking each of my views to find it though, since there were too many! Even if the dwg was in a view, I might have missed it if it sit underneath something else or outside of the view's crop boundaries...
For those having the same problem, I found the answer from this discussion on very same topic:
Anyway, does anyone know how to do this without resorting to DWG Explorer? This plugin works great, but I would prefer having its functionalities in Revit itself ...
