3d view to scale?
3d view to scale?
3d view to scale?
we have a 3d view on a sheet. the properties to the view says its to scale 1:50 - however its patently obviously not since there are plans and elevs on the same sheet to 1:50 and they are nowhere near....... how do we make it so?! is it possible?
Kimtaurus
Are you looking at the model at an angle?
If you're looking horizontally/vertically at the model, the length will be correct.  (if you click on the View Cube on Front/Left/Top... the lengts will be by scale)
When you're looking at an angle, the lines will obviously be shorter.
There's no isometric view in Revit.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
