Date Details not showing when opening project
abbyU4GQN
Message 1 of 8
abbyU4GQN
Hello, When I open Revit (2025) and select to open a project from file explorer, the 'open' window will not show the date stamp (snip attached). Under Views dropdown, Details is greyed out. I've tried looking in File Explorer options for a fix, and there is none that I can find. Is this perhaps related to a plugin?
Thoughts?
It makes opening the correct project version much more tedious than it ought to be.
Replies (7)
Message 2 of 8
RSomppi
It looks like details is already selected and the window isn't big enough to show the column.
Message 3 of 8
RDAOU
@abbyU4GQN
Right click on the Title bar where is says name and check/select Date Created, Date modified or both
Message 4 of 8
abbyU4GQN
no.. that's incorrect
Message 5 of 8
abbyU4GQN
THANK YOU SO MUCH!! This was it!
Message 6 of 8
RSomppi
So, details was already selected. I was correct in my analysis.
Message 7 of 8
abbyU4GQN
No, sorry. Details, as stated in the original was greyed out and could not be selected. It's ok to be incorrect! Be ok with it. I sincerely thank you for trying to help
Message 8 of 8
RSomppi
It's grayed out because it is already active. Tested and verified.
