Can't without deleting annotation
kevinpo
Message 1 of 17
kevinpo
So this has been bugging me for year. Why can we not not move items without all of the warning about how many annotative object have to be deleted? Yet I can nudge the heck out of it and eyeball to the new location and the objects remain.
This is supposed to be an accurate drawing platform; why do you make users go through this?
Come on AutoDesk you can do better..
Replies (16)
Message 2 of 17
RSomppi
Not really.
Would you rather not be warned about the impending doom of losing annotation?
Have you tried moving without "Disjoin" checked?
Message 3 of 17
SteveKStafford
As mentioned by @RSomppi make sure the Disjoin option is disabled for the Move tool. Disjoin deletes and recreates the element involved in the move, in the new location, to break a relationship with any other elements (thus the word disjoin).
Steve Stafford
Message 4 of 17
handjonathan
Hi @kevinpo
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @RSomppi @SteveKStafford helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 5 of 17
seydauzun
This problem is resolved in Revit 2024 for your info. I use align tool as a suggestion, when you move the elements with align rather then move, anno will be preserved.
Message 6 of 17
RSomppi
How is that? AFAIK, there has been no change in this for years. It's expected behavior.
Message 7 of 17
seydauzun
@RSomppi , this is our 2024 project in the video, and we do not lose dimensions. Is something wrong with us ? 😄
Message 8 of 17
RSomppi
It has always worked like that, that's not new for 2024.
Now try it with the "Disjoin" button checked.
Message 9 of 17
seydauzun
Not in previous versions
Message 10 of 17
RSomppi
Did you check the disjoin button?
Message 11 of 17
RDAOU
@seydauzun
May I disagree with that statement? "Has been Resolved" ??  I believe Move, Drag, and Nudge all work as expected, and there was no issue to resolve in the first place.
  • Disjoin, taken literally as a word, simply meants to disconnects some restraint between two components. If the component isn’t locked or pinned, this would typically refer to the dimension strings.
  • Unchecking Disjoin switches the Move command to Drag mode. Drag mode is essentially a simplified version of Move, even sharing the same icon.
The behavior of Move with and without Disjoin has been consistent for as long as I can remember. While I didn’t use 2024 and I am not sure id any changes were made in that version but I can confirm that in 2025.4, Move/Disjon functions as it always has.
In the GIF above, with a clean model containing just one wall, one desk and one dimension string, Revit won't complete the move unless the dimensions are disconnected/disjoined...Only when Disjoin is UNCHECKED, Move switchs to Drag
Edit: Sorry, the reply should have went to @kevinpo
Message 12 of 17
It works the same for every version.  DO NOT CHECK the Disjoin Box.
Message 13 of 17
seydauzun
All right, i was wrong
Message 14 of 17
Mbruno-JDB
Love this thread.  I hate so much when I try to move something and it wants to delete my tags.  I just end up dragging things.
Message 15 of 17
RSomppi
I also recommend putting off annotating until the modeling is finished as much as possible.
Message 16 of 17
Mbruno-JDB
Much more often than I would like, I've had extensive revisions, long into CDs.
Message 17 of 17
RSomppi
I wonder if @kevinpo, is ever going to chime in.
