Dashed Witness Lines.
Gmerson
Message 1 of 13
Gmerson
Can anyone tell me if dashed witness lines have been added to dimensions in Revit 2021.
Grahame
Replies (12)
Message 2 of 13
Jason_S
I am not seeing that as an option in 2021.
Message 3 of 13
You mean this?
Message 4 of 13
Gmerson
Yes. Can that be automated?
Message 5 of 13
Somewhat, but not exactly.
Using Mouse Functions: Select all Instances in View + Override Graphics in View: By Element. Change the Projection Line Pattern.
Message 6 of 13
Gmerson
Ok. So it's still all or nothing.
Thanks.
Message 7 of 13
martijn_pater
What do you mean? Simply skip select all in view step...
Message 8 of 13
Gmerson
I only wanted the lines attached to the building dashed, not all 3. (the line under the text)
Message 9 of 13
martijn_pater
You could just set a dim type to "Fixed to Dimension Line" and draw some annotation lines dashed/dotted/etc. Actually do this a lot of the time anyway (dimensioning to annotation lines), not always though, but because I very much dislike the dimensions getting deleted error... bit of a control thing I guess, have to admit sometimes there are some random dimensions floating around consequently...
Message 10 of 13
ChrisBXE93T
Did you double up your dimensions? Just wondering how the witness lines are shown dashed but not the line under the dimension value...
Message 11 of 13
iwaindia_3
Community Visitor
Community Visitor
How did you make this? Can you explain the procedure to attain this dashed lines in dimensions.
Message 12 of 13
infoK3R2R
ARGH why can't we override the witness line style?? Or the dimension line style for that matter!
Message 13 of 13
neha_ligal
It changed both horizontal and vertical line how did you change only one?
