第 1 条消息(共 9 条)
Dashed lines not showing solid line below
Today's issue . . .
Our drawings are very diagrammatic, influenced by our CAD drawings.
- items above counter height are a heavy dash-dot-dot line
- items at counter height are a solid line
- items below counter height are a lighter dashed line
This is controlled by a filter that changes the appearance of the lines if the object is Above or Below.
Currently in PDFs, if an above line is on top of a solid line, we're only seeing the dashed line and my project managers want it to appear solid.
How it appears in PDF
How it appears on screen in Revit, how the project manager wants to see it in PDF.
I feel the PDF is displaying correctly, as the above item/line is technically above the solid line.
