cut walls can see Linked Structural Model
1 REPLY 1
svartak3Q3FM
139 Views, 1 Reply
Hello, we have linked the structural model to our architectural model so in the RCPs we are seeing the structure through the walls. We have tried everything including filling in the walls but can still see it. Any solutions will be highly appreciated. Thank you
1 REPLY 1
RDAOU
in reply to: svartak3Q3FM
@svartak3Q3FM
In visibility Graphics RevitLinks tab >>> Set the Link Display By:Link and pick a reflected ceiling plan from the link. If no Reflected Ceiling plans are available in the link view do the following:
  1. Open Link
  2. From the Ribbon >> View >> create a Reflected ceiling plan
  3. Edit View Range and set the Cut Plane offset of the Link > than the Cut Plane offset in the Host (ie: if in the Host model 2300...set it the link 2400)
  4. Save
  5. Open Host Model and reload Link
  6. On the RC Plan go to V/G >> RvtLinks tab >> set visibility By: Link and pick the RC plan you created in 2
The Structural elements should no longer show cutting/overlaying the walls
Forma Design Contest
Technology Administrators
