Cut plane not cutting all Elements of exact same Family
ggq.owyu
ggq.owyu
Cut plane not cutting all Elements of exact same Family.
What could be the cause?
Object in red circle is correct.
Can't attach Revit-File yet, maybe first post.
ggq.owyu
Here is the revit file.
Revit 2021.1.3
RDAOU
@ggq.owyu
I do not have revit atm but I assume 1 of 2 things (Either it is not cut by the view range cut plane OR the family is set to show pre-cut in plan views)...If you have already checked the view range/cut plane, Try the following:
Edit the family >> On the properties palette >> Uncheck "Show Family Pre-Cut in plan views"
Reload into the project
ggq.owyu
Thanks a lot, it worked.
