Corner mullion detail
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
vitaliy0001
656 Aufrufe, 3 Antworten
How can I extend the panels to the corner of the corner mullion, instead of them terminating at the corner mullion edge?
With the regular mullions, I simply offset them and the panels joined automatically.  This doesn't happen at corners for some reason.
3 ANTWORTEN 3
Nachricht 2 von 4
RDAOU
als Antwort auf: vitaliy0001
@vitaliy0001
Use a custom Curtain wall Panel that extends beyond the Left&Right bounding planes in the family..
If you want to make your life easier (Based on the image you have posted)...use 2x curtain systems
  1. the first system ..Only mullions (with Empty System Panel)
  2. the second system is Only Glass (set all mullions to none)
Nachricht 3 von 4
@vitaliy0001
Another option if you are using a System panel type is to unpin the panel (if pinned), edit in place and stretch it to overlap the corner mullion.
Nachricht 4 von 4
vitaliy0001
Thank you both.
