Cut geometry - Extrusion with Wall
2 REPLIES 2
ferhatkarakaya
566 Views, 2 Replies
Hi guys,
I have an extrusion which i want to cut because it goes through a wall. Does anyone have an idea what I can do? The command "cut geometry" doesn't seem to work.
2 REPLIES 2
RDAOU
in reply to: ferhatkarakaya
@ferhatkarakaya
You have 2 several options
Option 1: edit the extrusion and shape the sketch line to align with the wall (ie: no more protruding corner and no need for cut)
Optuin 2:  cut with a void
  1. Go to component > model in place
  2. Select a category
  3. Create a Void extrusion
  4. Important: use cut geometry and pick both the void and the element to cut
  5. Finish the in place model
ferhatkarakaya
in reply to: RDAOU
Thank you so much! it worked with the void model! I didnt need to use "cut geometry" at all
