I try to cut the highlighted beam but when select the ref plan cut on the other side.
Someone can help adn explane me how can I do to achieve of the result'
Thank's
Solved by ToanDN. Go to Solution.
Solved by MostafaElashmawy. Go to Solution.
You should click cut then the part that you need it to stay then the reference plan.
Mostafa Elashmawy
sorry didn't notice the photo.
Revit will cut the smaller part usually.
Draw the reference plan near to the right edge then cut then move the reference plan to left.
Mostafa Elashmawy
@MostafaElashmawy I've tryed 1000 times but the result is the same part, remains the left.
If you try for me and upload the file you would be kind, thank's.
.rvt is attached on the first mess.
Mostafa Elashmawy
