Cut beam on the correct side
Message 1 of 8
I try to cut the highlighted beam but when select the ref plan cut on the other side.
Someone can help adn explane me how can I do to achieve of the result'
Thank's
Replies (7)
Message 2 of 8
MostafaElashmawy
You should click cut then the part that you need it to stay then the reference plan.
Mostafa Elashmawy
Message 3 of 8
MostafaElashmawy
sorry didn't notice the photo.
Revit will cut the smaller part usually.
Draw the reference plan near to the right edge then cut then move the reference plan to left.
Mostafa Elashmawy
Message 4 of 8
@MostafaElashmawy  I've tryed 1000 times but the result is the same part, remains the left.
If you try for me and upload the file you would be kind, thank's.
.rvt is attached on the first mess.
Message 5 of 8
MostafaElashmawy
Mostafa Elashmawy
Message 6 of 8
Unpin, shorten the beam, cut.
Message 7 of 8
ecentenera
This didn't work for me it keeps cutting the wrong/larger side even if I already adjusted the one to be cut.
Message 8 of 8
ecentenera
workaround is i just added another structural frame and deleted the frames that can't be cut correctly from the beam system.
