Cut and Fill: No Response
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I'm encountering an issue with cut and fill operations. Here's the process I followed:
- I created a Toposolid in the existing phase.
- I used the "Graded Region" tool to create a new Toposurface that matches the existing one, changing the phase to preparation.
- I attempted to trim my Toposolid, which was created by the Graded Region.
However, I'm puzzled because the cut and fill values remain unchanged, even when I try to make significant alterations. Interestingly, when I copy the original Toposolid and test it in a different file using the same process, the cut and fill values are correct. I'm uploading the file if someone could help
I also have a second question: Is there a way to copy the points from the Toposolid? It's quite time-consuming to trim the Toposolid repeatedly.
