Editable Titleblock
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
tstewart
424 Aufrufe, 6 Antworten
Editable Titleblock
I've created a new Titleblock and saved/loaded it into Titleblock Family. Whenever I add a sheet into the project, the old titleblock appears and is not editable. How can I add the new Titleblock as the default Titleblock for all sheets?
6 ANTWORTEN 6
Nachricht 2 von 7
syman2000
als Antwort auf: tstewart
I would right click on the existing titleblock and select all instance in the entire project
Afterward, you swap it out with the new titleblock
Nachricht 3 von 7
tstewart
als Antwort auf: syman2000
OH HAPPY DAY!!! Thank you much.
Nachricht 4 von 7
tstewart
I celebrated too soon. The new TB was saved & loaded into project, although the old TB is still displaying. What am I missing???
Nachricht 5 von 7
syman2000
You have to delete it from the project browser or purge it. Easiest way is to search the old titleblock and right click and delete it.
Nachricht 6 von 7
tstewart
I overwrote the D22x34 Titleblock, so if I delete it will that disappear in the project?
TS
Nachricht 7 von 7
syman2000
Yes it will disappear from the project. Before you do that, I would save the family to file and the proceed with the removing the family from the project.
