Custom Viewport Title - incorrect display
- Mute
- Permalink
- Report
Ok, so I’ve created a custom viewport title, but it has some…curiosities…which I can’t figure out.
See the images below.
So as per IMAGE 1 its a simple title, just the view number in a box/View Name label/View scale label. The first issue is that if I line up the labels neatly in the family, when in use in the project the scale text is always offset slightly to the right. To combat this, I offset the label to the left so that when in use it displays correctly (IMAGE 2)
However creating a custom scale on a floorplan view (in this case 1:1250) causes the scale text to display where the label is actually located in the family, so when used in a project the custom scale is offset too far to the left (IMAGE 3)
I can’t figure a way around this, any thoughts appreciated!
IMAGE 1 (Family/label view)
IMAGE 2 (Correct display with standard scale)
IMAGE 3 (incorrect display with custom scale)
